Time Before: 0.00141 seconds
Time After: 0.00192 seconds
Time Before: 0.00199 seconds
Time After: 0.00231 seconds
Time Before: 0.00251 seconds
Time After: 0.00261 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00322 seconds
Time After: 0.00567 seconds
Time Taken: 0.00244 seconds
Time Before: 0.00266 seconds
Time After: 0.00925 seconds
Time Taken: 0.00659 seconds
Time Before: 0.01098 seconds
Time After: 0.01143 seconds
Time Before: 0.01395 seconds
Time After: 0.01511 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01040 seconds
Time After: 0.01528 seconds
Time Taken: 0.00488 seconds
Time Before: 0.02096 seconds
Time After: 0.02120 seconds
Time Before: 0.02393 seconds
Time After: 0.02521 seconds
Time Before: 0.02967 seconds
Time After: 0.02986 seconds
Time Before: 0.03308 seconds
Time After: 0.03479 seconds
Time Taken: 0.00171 seconds
UPDATE session SET lastactivity = 1789070310, location = '/forums/private.php?do=newpm&explain=1&u=117409' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04900 seconds
Time After: 0.04932 seconds
