Time Before: 0.00188 seconds
Time After: 0.00246 seconds
Time Taken: 0.00058 seconds
Memory Before: 532.883 KB
Memory After: 558.000 KB
Time Before: 0.00253 seconds
Time After: 0.00301 seconds
Memory Before: 557.938 KB
Memory After: 558.945 KB
Time Before: 0.00326 seconds
Time After: 0.00340 seconds
Memory Before: 559.500 KB
Memory After: 560.023 KB
Time Before: 0.00503 seconds
Time After: 0.00956 seconds
Time Taken: 0.00453 seconds
Memory Before: 562.625 KB
Memory After: 563.547 KB
Time Before: 0.00345 seconds
Time After: 0.01453 seconds
Time Taken: 0.01107 seconds
Memory Before: 559.273 KB
Memory After: 1,640.320 KB
Memory Used: 1,081.047 KB
Time Before: 0.01681 seconds
Time After: 0.01729 seconds
Memory Before: 2,135.250 KB
Memory After: 2,135.867 KB
Time Before: 0.01982 seconds
Time After: 0.02124 seconds
Memory Before: 2,147.414 KB
Memory After: 2,147.273 KB
Time Before: 0.01617 seconds
Time After: 0.02146 seconds
Time Taken: 0.00529 seconds
Memory Before: 2,127.430 KB
Memory After: 2,260.641 KB
Memory Used: 133.211 KB
Time Before: 0.02751 seconds
Time After: 0.02765 seconds
Memory Before: 2,814.180 KB
Memory After: 2,814.695 KB
Time Before: 0.03002 seconds
Time After: 0.03131 seconds
Memory Before: 2,902.500 KB
Memory After: 2,903.094 KB
Time Before: 0.03458 seconds
Time After: 0.03476 seconds
Memory Before: 3,539.297 KB
Memory After: 3,539.727 KB
Time Before: 0.03793 seconds
Time After: 0.03951 seconds
Time Taken: 0.00158 seconds
Memory Before: 3,820.828 KB
Memory After: 3,822.516 KB
UPDATE session SET lastactivity = 1785352960, location = '/forums/private.php?do=newpm&explain=1&u=117423', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.05325 seconds
Time After: 0.05410 seconds
Time Taken: 0.00085 seconds
Memory Before: 4,299.438 KB
Memory After: 4,299.648 KB
