Time Before: 0.02285 seconds
Time After: 0.03285 seconds
Time Taken: 0.01000 seconds
Time Before: 0.03297 seconds
Time After: 0.03357 seconds
Time Taken: 0.00060 seconds
Time Before: 0.03383 seconds
Time After: 0.03394 seconds
Time Before: 0.03472 seconds
Time After: 0.03726 seconds
Time Taken: 0.00254 seconds
Time Before: 0.03401 seconds
Time After: 0.04156 seconds
Time Taken: 0.00756 seconds
Time Before: 0.05196 seconds
Time After: 0.05238 seconds
Time Before: 0.05501 seconds
Time After: 0.05621 seconds
Time Before: 0.05123 seconds
Time After: 0.05647 seconds
Time Taken: 0.00524 seconds
Time Before: 0.09633 seconds
Time After: 0.09671 seconds
Time Before: 0.12085 seconds
Time After: 0.12213 seconds
End call of global.php: 0.12415814399719
Time Before: 0.13442 seconds
Time After: 0.13458 seconds
Time Before: 0.13716 seconds
Time After: 0.13858 seconds
SET lastactivity = 1776873027, location = '/forums/private.php?do=newpm&explain=1&u=117446', badlocation = 1
Time Before: 0.15856 seconds
Time After: 0.15884 seconds
Page generated in 0.15742802619934 seconds with 9 queries, spending 0.0083858966827393 doing MySQL queries and 0.1490421295166 doing PHP things.
