Time Before: 0.01407 seconds
Time After: 0.01864 seconds
Time Taken: 0.00458 seconds
Time Before: 0.01874 seconds
Time After: 0.01919 seconds
Time Before: 0.01942 seconds
Time After: 0.01955 seconds
Time Before: 0.02033 seconds
Time After: 0.02299 seconds
Time Taken: 0.00266 seconds
Time Before: 0.01962 seconds
Time After: 0.02728 seconds
Time Taken: 0.00766 seconds
Time Before: 0.03305 seconds
Time After: 0.03341 seconds
Time Before: 0.03595 seconds
Time After: 0.03715 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03238 seconds
Time After: 0.03737 seconds
Time Taken: 0.00499 seconds
Memory After: 2,261.820 KB
Time Before: 0.06114 seconds
Time After: 0.06131 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"34.50,\";s:9:\"lastcheck\";i:1789118753;}', 1)Time Before: 0.07291 seconds
Time After: 0.07361 seconds
Time Taken: 0.00071 seconds
Memory Before: 2,816.633 KB
Memory After: 2,816.883 KB
Memory Used: 0.250 KB
Time Before: 0.09294 seconds
Time After: 0.09445 seconds
Time Taken: 0.00151 seconds
Memory Before: 2,903.938 KB
Memory After: 2,904.531 KB
Time Before: 0.10501 seconds
Time After: 0.10515 seconds
Memory Before: 3,540.688 KB
Memory After: 3,541.117 KB
Time Before: 0.10770 seconds
Time After: 0.10912 seconds
Memory Before: 3,822.422 KB
Memory After: 3,824.109 KB
UPDATE session SET lastactivity = 1789118753, location = '/forums/private.php?do=newpm&explain=1&u=117513', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.12800 seconds
Time After: 0.12827 seconds
Memory Before: 4,296.438 KB
Memory After: 4,296.648 KB
