Time Before: 0.01347 seconds
Time After: 0.01797 seconds
Time Taken: 0.00450 seconds
Time Before: 0.01807 seconds
Time After: 0.01856 seconds
Time Before: 0.01882 seconds
Time After: 0.01907 seconds
Time Before: 0.01984 seconds
Time After: 0.02264 seconds
Time Taken: 0.00281 seconds
Time Before: 0.01913 seconds
Time After: 0.02682 seconds
Time Taken: 0.00770 seconds
Time Before: 0.03286 seconds
Time After: 0.03325 seconds
Time Before: 0.03551 seconds
Time After: 0.03675 seconds
Time Before: 0.03214 seconds
Time After: 0.03692 seconds
Time Taken: 0.00478 seconds
Time Before: 0.05440 seconds
Time After: 0.05467 seconds
Time Before: 0.06411 seconds
Time After: 0.06537 seconds
End call of global.php: 0.06761908531189
Time Before: 0.07257 seconds
Time After: 0.07275 seconds
Time Before: 0.07520 seconds
Time After: 0.07695 seconds
Time Taken: 0.00175 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=117517', badlocation = 1
Time Before: 0.09210 seconds
Time After: 0.09252 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.091078996658325 seconds with 9 queries, spending 0.0090627670288086 doing MySQL queries and 0.082016229629517 doing PHP things.
