Time Before: 0.00140 seconds
Time After: 0.00187 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00194 seconds
Time After: 0.00260 seconds
Time Taken: 0.00065 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00289 seconds
Time After: 0.00301 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00370 seconds
Time After: 0.00655 seconds
Time Taken: 0.00285 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00306 seconds
Time After: 0.01000 seconds
Time Taken: 0.00694 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01224 seconds
Time After: 0.01272 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01526 seconds
Time After: 0.01657 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,771.539 KB
Memory After: 2,771.398 KB
Time Before: 0.01158 seconds
Time After: 0.01674 seconds
Time Taken: 0.00516 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.430 KB
Time Before: 0.02185 seconds
Time After: 0.02200 seconds
Memory Before: 3,437.555 KB
Memory After: 3,438.070 KB
Time Before: 0.02385 seconds
Time After: 0.02509 seconds
Memory Before: 3,525.352 KB
Memory After: 3,525.945 KB
End call of global.php: 0.02685284614563
Time Before: 0.02810 seconds
Time After: 0.02833 seconds
Memory Before: 4,163.250 KB
Memory After: 4,163.680 KB
Time Before: 0.03038 seconds
Time After: 0.03185 seconds
Memory Before: 4,444.789 KB
Memory After: 4,446.477 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=117529'
WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.04489 seconds
Time After: 0.04518 seconds
Memory Before: 4,918.398 KB
Memory After: 4,918.641 KB
Page generated in 0.044014930725098 seconds with 9 queries, spending 0.0087990760803223 doing MySQL queries and 0.035215854644775 doing PHP things.
