Time Before: 0.00172 seconds
Time After: 0.00237 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00251 seconds
Time After: 0.00298 seconds
Time Before: 0.00328 seconds
Time After: 0.00353 seconds
Time Before: 0.00434 seconds
Time After: 0.00649 seconds
Time Taken: 0.00216 seconds
Time Before: 0.00361 seconds
Time After: 0.00995 seconds
Time Taken: 0.00634 seconds
Time Before: 0.01182 seconds
Time After: 0.01223 seconds
Time Before: 0.01376 seconds
Time After: 0.01498 seconds
Time Before: 0.01122 seconds
Time After: 0.01523 seconds
Time Taken: 0.00401 seconds
Time Before: 0.02128 seconds
Time After: 0.02145 seconds
Time Before: 0.02355 seconds
Time After: 0.02477 seconds
Time Before: 0.02831 seconds
Time After: 0.02847 seconds
Time Before: 0.03091 seconds
Time After: 0.03261 seconds
Time Taken: 0.00170 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=117531' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.04539 seconds
Time After: 0.04570 seconds
