Time Before: 0.00204 seconds
Time After: 0.00259 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00270 seconds
Time After: 0.00305 seconds
Time Before: 0.00329 seconds
Time After: 0.00339 seconds
Time Before: 0.00417 seconds
Time After: 0.00860 seconds
Time Taken: 0.00443 seconds
Time Before: 0.00347 seconds
Time After: 0.01379 seconds
Time Taken: 0.01033 seconds
Time Before: 0.01620 seconds
Time After: 0.01650 seconds
Time Before: 0.01881 seconds
Time After: 0.01996 seconds
Time Taken: 0.00115 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01550 seconds
Time After: 0.02018 seconds
Time Taken: 0.00468 seconds
Memory After: 2,261.719 KB
Memory Used: 132.781 KB
Time Before: 0.02727 seconds
Time After: 0.02746 seconds
Memory Before: 2,815.305 KB
Memory After: 2,815.820 KB
Time Before: 0.02921 seconds
Time After: 0.03054 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,903.508 KB
Memory After: 2,904.102 KB
End call of global.php: 0.032181978225708
Time Before: 0.03323 seconds
Time After: 0.03334 seconds
Memory Before: 3,540.266 KB
Memory After: 3,540.695 KB
Time Before: 0.03522 seconds
Time After: 0.03661 seconds
Time Taken: 0.00139 seconds
Memory Before: 3,821.797 KB
Memory After: 3,823.484 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=117540'
Time Before: 0.04962 seconds
Time After: 0.05016 seconds
Time Taken: 0.00053 seconds
Memory Before: 4,287.211 KB
Memory After: 4,287.453 KB
Page generated in 0.048500061035156 seconds with 9 queries, spending 0.0099048614501953 doing MySQL queries and 0.038595199584961 doing PHP things.
