Time Before: 0.00214 seconds
Time After: 0.00291 seconds
Time Taken: 0.00077 seconds
Time Before: 0.00298 seconds
Time After: 0.00341 seconds
Time Before: 0.00371 seconds
Time After: 0.00391 seconds
Time Before: 0.00467 seconds
Time After: 0.00748 seconds
Time Taken: 0.00281 seconds
Time Before: 0.00398 seconds
Time After: 0.01090 seconds
Time Taken: 0.00692 seconds
Time Before: 0.01265 seconds
Time After: 0.01305 seconds
Time Before: 0.01494 seconds
Time After: 0.01609 seconds
Time Taken: 0.00115 seconds
Time Before: 0.01214 seconds
Time After: 0.01626 seconds
Time Taken: 0.00412 seconds
Time Before: 0.02121 seconds
Time After: 0.02134 seconds
Time Before: 0.02313 seconds
Time After: 0.02437 seconds
Time Before: 0.02704 seconds
Time After: 0.02718 seconds
Time Before: 0.02898 seconds
Time After: 0.03040 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=117551', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.04268 seconds
Time After: 0.04295 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
