Time Before: 0.01634 seconds
Time After: 0.02140 seconds
Time Taken: 0.00506 seconds
Time Before: 0.02150 seconds
Time After: 0.02193 seconds
Time Before: 0.02218 seconds
Time After: 0.02234 seconds
Time Before: 0.02332 seconds
Time After: 0.02570 seconds
Time Taken: 0.00238 seconds
Time Before: 0.02241 seconds
Time After: 0.03008 seconds
Time Taken: 0.00767 seconds
Time Before: 0.04048 seconds
Time After: 0.04098 seconds
Time Before: 0.04437 seconds
Time After: 0.04555 seconds
Time Taken: 0.00118 seconds
Time Before: 0.03978 seconds
Time After: 0.04575 seconds
Time Taken: 0.00596 seconds
Time Before: 0.09021 seconds
Time After: 0.09037 seconds
Time Before: 0.10833 seconds
Time After: 0.10958 seconds
Time Before: 0.12268 seconds
Time After: 0.12284 seconds
Time Before: 0.12581 seconds
Time After: 0.12728 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=117559' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.14549 seconds
Time After: 0.14773 seconds
Time Taken: 0.00224 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
