Time Before: 0.00138 seconds
Time After: 0.00191 seconds
Time Before: 0.00197 seconds
Time After: 0.00249 seconds
Time Before: 0.00279 seconds
Time After: 0.00293 seconds
Time Before: 0.00357 seconds
Time After: 0.00614 seconds
Time Taken: 0.00256 seconds
Time Before: 0.00298 seconds
Time After: 0.00956 seconds
Time Taken: 0.00658 seconds
Time Before: 0.01198 seconds
Time After: 0.01233 seconds
Time Before: 0.01471 seconds
Time After: 0.01595 seconds
Time Before: 0.01133 seconds
Time After: 0.01612 seconds
Time Taken: 0.00479 seconds
Time Before: 0.02133 seconds
Time After: 0.02149 seconds
Time Before: 0.02339 seconds
Time After: 0.02470 seconds
Time Taken: 0.00131 seconds
Time Before: 0.02776 seconds
Time After: 0.02792 seconds
Time Before: 0.03020 seconds
Time After: 0.03170 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=117612', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04479 seconds
Time After: 0.04521 seconds
