Time Before: 0.00180 seconds
Time After: 0.00265 seconds
Time Taken: 0.00085 seconds
Time Before: 0.00275 seconds
Time After: 0.00315 seconds
Time Before: 0.00339 seconds
Time After: 0.00351 seconds
Time Before: 0.00432 seconds
Time After: 0.00671 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00359 seconds
Time After: 0.01129 seconds
Time Taken: 0.00770 seconds
Time Before: 0.01517 seconds
Time After: 0.01564 seconds
Time Before: 0.01815 seconds
Time After: 0.01935 seconds
Time Before: 0.01446 seconds
Time After: 0.01958 seconds
Time Taken: 0.00512 seconds
Time Before: 0.02807 seconds
Time After: 0.02819 seconds
Time Before: 0.03089 seconds
Time After: 0.03219 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.034014225006104
Time Before: 0.03559 seconds
Time After: 0.03575 seconds
Time Before: 0.03792 seconds
Time After: 0.03936 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=117656', badlocation = 1
Time Before: 0.05205 seconds
Time After: 0.05228 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.051122188568115 seconds with 9 queries, spending 0.0078186988830566 doing MySQL queries and 0.043303489685059 doing PHP things.
