Time Before: 0.02154 seconds
Time After: 0.03077 seconds
Time Taken: 0.00923 seconds
Time Before: 0.03087 seconds
Time After: 0.03129 seconds
Time Before: 0.03151 seconds
Time After: 0.03164 seconds
Time Before: 0.03234 seconds
Time After: 0.03481 seconds
Time Taken: 0.00246 seconds
Time Before: 0.03172 seconds
Time After: 0.03922 seconds
Time Taken: 0.00751 seconds
Time Before: 0.04828 seconds
Time After: 0.04885 seconds
Time Taken: 0.00057 seconds
Time Before: 0.05176 seconds
Time After: 0.05294 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04720 seconds
Time After: 0.05320 seconds
Time Taken: 0.00600 seconds
Memory After: 2,261.820 KB
Time Before: 0.08011 seconds
Time After: 0.08024 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 1.90557 seconds
Time After: 1.90749 seconds
Time Taken: 0.00192 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 1.91553 seconds
Time After: 1.91571 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 1.91814 seconds
Time After: 1.91967 seconds
Time Taken: 0.00153 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789125114, location = '/forums/private.php?do=newpm&explain=1&u=117680' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 1.93848 seconds
Time After: 1.93876 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
