Time Before: 0.00310 seconds
Time After: 0.00376 seconds
Time Taken: 0.00066 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00387 seconds
Time After: 0.00429 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00451 seconds
Time After: 0.00465 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00543 seconds
Time After: 0.00786 seconds
Time Taken: 0.00243 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00472 seconds
Time After: 0.01129 seconds
Time Taken: 0.00656 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01311 seconds
Time After: 0.01347 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01622 seconds
Time After: 0.01742 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.01252 seconds
Time After: 0.01759 seconds
Time Taken: 0.00507 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.02351 seconds
Time After: 0.02365 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.03034 seconds
Time After: 0.03158 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
End call of global.php: 0.033226013183594
Time Before: 0.03940 seconds
Time After: 0.03963 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.04167 seconds
Time After: 0.04320 seconds
Time Taken: 0.00153 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=117700'
WHERE sessionhash = '8385044bee7d6de684cfeaf823df6777'
Time Before: 0.05626 seconds
Time After: 0.05659 seconds
Memory Before: 5,997.547 KB
Memory After: 5,997.789 KB
Page generated in 0.055345058441162 seconds with 9 queries, spending 0.0080165863037109 doing MySQL queries and 0.047328472137451 doing PHP things.
