Time Before: 0.00304 seconds
Time After: 0.00381 seconds
Time Taken: 0.00077 seconds
Memory Before: 533.930 KB
Memory After: 559.047 KB
Time Before: 0.00393 seconds
Time After: 0.00455 seconds
Time Taken: 0.00062 seconds
Memory Before: 558.984 KB
Memory After: 559.992 KB
Time Before: 0.00524 seconds
Time After: 0.00552 seconds
Memory Before: 560.547 KB
Memory After: 561.070 KB
Time Before: 0.00628 seconds
Time After: 0.00935 seconds
Time Taken: 0.00307 seconds
Memory Before: 563.672 KB
Memory After: 564.594 KB
Time Before: 0.00558 seconds
Time After: 0.01275 seconds
Time Taken: 0.00717 seconds
Memory Before: 560.320 KB
Memory After: 1,641.344 KB
Memory Used: 1,081.023 KB
Time Before: 0.01464 seconds
Time After: 0.01502 seconds
Memory Before: 2,136.219 KB
Memory After: 2,136.836 KB
Time Before: 0.01640 seconds
Time After: 0.01758 seconds
Memory Before: 2,148.398 KB
Memory After: 2,148.258 KB
Time Before: 0.01405 seconds
Time After: 0.01775 seconds
Time Taken: 0.00370 seconds
Memory Before: 2,128.398 KB
Memory After: 2,261.281 KB
Time Before: 0.02441 seconds
Time After: 0.02454 seconds
Memory Before: 2,814.875 KB
Memory After: 2,815.391 KB
Time Before: 0.02723 seconds
Time After: 0.02859 seconds
Time Taken: 0.00136 seconds
Memory Before: 2,903.211 KB
Memory After: 2,903.805 KB
Time Before: 0.03248 seconds
Time After: 0.03262 seconds
Memory Before: 3,539.984 KB
Memory After: 3,540.414 KB
Time Before: 0.03544 seconds
Time After: 0.03687 seconds
Memory Before: 3,821.516 KB
Memory After: 3,823.203 KB
UPDATE session SET lastactivity = 1788893617, location = '/forums/private.php?do=newpm&explain=1&u=117741' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05389 seconds
Time After: 0.05416 seconds
Memory Before: 4,295.383 KB
Memory After: 4,295.609 KB
