Time Before: 0.00140 seconds
Time After: 0.00194 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00201 seconds
Time After: 0.00255 seconds
Time Before: 0.00281 seconds
Time After: 0.00295 seconds
Time Before: 0.00391 seconds
Time After: 0.00634 seconds
Time Taken: 0.00243 seconds
Time Before: 0.00303 seconds
Time After: 0.01107 seconds
Time Taken: 0.00804 seconds
Time Before: 0.01311 seconds
Time After: 0.01335 seconds
Time Before: 0.01658 seconds
Time After: 0.01779 seconds
Time Before: 0.01242 seconds
Time After: 0.01798 seconds
Time Taken: 0.00556 seconds
Time Before: 0.02361 seconds
Time After: 0.02377 seconds
Time Before: 0.02549 seconds
Time After: 0.02669 seconds
End call of global.php: 0.028836965560913
Time Before: 0.03046 seconds
Time After: 0.03062 seconds
Time Before: 0.03349 seconds
Time After: 0.03494 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=117844', badlocation = 1
Time Before: 0.04902 seconds
Time After: 0.04935 seconds
Page generated in 0.048062801361084 seconds with 9 queries, spending 0.0078518390655518 doing MySQL queries and 0.040210962295532 doing PHP things.
