Time Before: 0.02423 seconds
Time After: 0.03414 seconds
Time Taken: 0.00991 seconds
Time Before: 0.03425 seconds
Time After: 0.03471 seconds
Time Before: 0.03500 seconds
Time After: 0.03523 seconds
Time Before: 0.03604 seconds
Time After: 0.03917 seconds
Time Taken: 0.00313 seconds
Time Before: 0.03532 seconds
Time After: 0.04334 seconds
Time Taken: 0.00802 seconds
Time Before: 0.05986 seconds
Time After: 0.06009 seconds
Time Before: 0.06259 seconds
Time After: 0.06375 seconds
Time Taken: 0.00116 seconds
Time Before: 0.05918 seconds
Time After: 0.06398 seconds
Time Taken: 0.00480 seconds
Time Before: 0.11014 seconds
Time After: 0.11034 seconds
Time Before: 0.13455 seconds
Time After: 0.13576 seconds
Time Before: 0.15180 seconds
Time After: 0.15198 seconds
Time Before: 0.15446 seconds
Time After: 0.15586 seconds
UPDATE session SET lastactivity = 1783256239, location = '/forums/private.php?do=newpm&explain=1&u=117860', badlocation = 1 WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.17789 seconds
Time After: 0.17814 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
