Time Before: 0.00972 seconds
Time After: 0.01301 seconds
Time Taken: 0.00329 seconds
Time Before: 0.01310 seconds
Time After: 0.01354 seconds
Time Before: 0.01384 seconds
Time After: 0.01403 seconds
Time Before: 0.01503 seconds
Time After: 0.01790 seconds
Time Taken: 0.00287 seconds
Time Before: 0.01411 seconds
Time After: 0.02196 seconds
Time Taken: 0.00785 seconds
Time Before: 0.02792 seconds
Time After: 0.02829 seconds
Time Before: 0.03094 seconds
Time After: 0.03241 seconds
Time Before: 0.02724 seconds
Time After: 0.03266 seconds
Time Taken: 0.00542 seconds
Time Before: 0.05273 seconds
Time After: 0.05288 seconds
Time Before: 0.06405 seconds
Time After: 0.06542 seconds
Time Taken: 0.00137 seconds
End call of global.php: 0.067594051361084
Time Before: 0.07125 seconds
Time After: 0.07151 seconds
Time Before: 0.07449 seconds
Time After: 0.07601 seconds
Time Taken: 0.00152 seconds
SET lastactivity = 1783172284, location = '/forums/private.php?do=newpm&explain=1&u=117872', badlocation = 1
Time Before: 0.09909 seconds
Time After: 0.09941 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
Page generated in 0.097651958465576 seconds with 9 queries, spending 0.0089459419250488 doing MySQL queries and 0.088706016540527 doing PHP things.
