Time Before: 0.02782 seconds
Time After: 0.03365 seconds
Time Taken: 0.00583 seconds
Time Before: 0.03374 seconds
Time After: 0.03421 seconds
Time Before: 0.03444 seconds
Time After: 0.03459 seconds
Time Before: 0.03542 seconds
Time After: 0.03839 seconds
Time Taken: 0.00296 seconds
Time Before: 0.03467 seconds
Time After: 0.04267 seconds
Time Taken: 0.00800 seconds
Time Before: 0.05183 seconds
Time After: 0.05208 seconds
Time Before: 0.05461 seconds
Time After: 0.05584 seconds
Time Before: 0.05093 seconds
Time After: 0.05607 seconds
Time Taken: 0.00513 seconds
Time Before: 0.09560 seconds
Time After: 0.09574 seconds
Time Before: 0.10733 seconds
Time After: 0.10874 seconds
Time Before: 0.12122 seconds
Time After: 0.12136 seconds
Time Before: 0.12357 seconds
Time After: 0.12499 seconds
UPDATE session SET lastactivity = 1782923242, location = '/forums/private.php?do=newpm&explain=1&u=117896', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.14814 seconds
Time After: 0.16473 seconds
Time Taken: 0.01659 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
