Time Before: 0.00143 seconds
Time After: 0.00192 seconds
Time Before: 0.00199 seconds
Time After: 0.00273 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00295 seconds
Time After: 0.00309 seconds
Time Before: 0.00376 seconds
Time After: 0.00633 seconds
Time Taken: 0.00256 seconds
Time Before: 0.00314 seconds
Time After: 0.01126 seconds
Time Taken: 0.00813 seconds
Time Before: 0.01360 seconds
Time After: 0.01398 seconds
Time Before: 0.01565 seconds
Time After: 0.01702 seconds
Time Taken: 0.00137 seconds
Time Before: 0.01283 seconds
Time After: 0.01723 seconds
Time Taken: 0.00440 seconds
Time Before: 0.02281 seconds
Time After: 0.02295 seconds
Time Before: 0.02605 seconds
Time After: 0.02736 seconds
Time Taken: 0.00131 seconds
Time Before: 0.03161 seconds
Time After: 0.03177 seconds
Time Before: 0.03470 seconds
Time After: 0.03618 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=117921', badlocation = 1 WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.05020 seconds
Time After: 0.05044 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
