Time Before: 0.01001 seconds
Time After: 0.01299 seconds
Time Taken: 0.00298 seconds
Time Before: 0.01307 seconds
Time After: 0.01358 seconds
Time Before: 0.01384 seconds
Time After: 0.01399 seconds
Time Before: 0.01490 seconds
Time After: 0.01731 seconds
Time Taken: 0.00241 seconds
Time Before: 0.01407 seconds
Time After: 0.02146 seconds
Time Taken: 0.00739 seconds
Time Before: 0.02599 seconds
Time After: 0.02641 seconds
Time Before: 0.02799 seconds
Time After: 0.02918 seconds
Time Before: 0.02536 seconds
Time After: 0.02940 seconds
Time Taken: 0.00403 seconds
Time Before: 0.04657 seconds
Time After: 0.04674 seconds
Time Before: 0.05878 seconds
Time After: 0.06007 seconds
Time Before: 0.06612 seconds
Time After: 0.06628 seconds
Time Before: 0.06896 seconds
Time After: 0.07041 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=117946' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.08594 seconds
Time After: 0.08627 seconds
