Time Before: 0.00143 seconds
Time After: 0.00199 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00206 seconds
Time After: 0.00262 seconds
Time Before: 0.00284 seconds
Time After: 0.00295 seconds
Time Before: 0.00372 seconds
Time After: 0.00664 seconds
Time Taken: 0.00292 seconds
Time Before: 0.00301 seconds
Time After: 0.01005 seconds
Time Taken: 0.00704 seconds
Time Before: 0.01179 seconds
Time After: 0.01221 seconds
Time Before: 0.01360 seconds
Time After: 0.01478 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01120 seconds
Time After: 0.01494 seconds
Time Taken: 0.00374 seconds
Time Before: 0.02179 seconds
Time After: 0.02193 seconds
Time Before: 0.02412 seconds
Time After: 0.02537 seconds
End call of global.php: 0.028274059295654
Time Before: 0.02969 seconds
Time After: 0.03000 seconds
Time Before: 0.03248 seconds
Time After: 0.03388 seconds
Time Taken: 0.00140 seconds
SET lastactivity = 1785389084, location = '/forums/private.php?do=newpm&explain=1&u=117966', badlocation = 1
Time Before: 0.04686 seconds
Time After: 0.04714 seconds
Page generated in 0.045623064041138 seconds with 9 queries, spending 0.0085632801055908 doing MySQL queries and 0.037059783935547 doing PHP things.
