Time Before: 0.00952 seconds
Time After: 0.01311 seconds
Time Taken: 0.00359 seconds
Time Before: 0.01320 seconds
Time After: 0.01373 seconds
Time Taken: 0.00053 seconds
Time Before: 0.01398 seconds
Time After: 0.01416 seconds
Time Before: 0.01496 seconds
Time After: 0.01727 seconds
Time Taken: 0.00231 seconds
Time Before: 0.01424 seconds
Time After: 0.02164 seconds
Time Taken: 0.00740 seconds
Time Before: 0.02913 seconds
Time After: 0.02967 seconds
Time Taken: 0.00054 seconds
Time Before: 0.03219 seconds
Time After: 0.03346 seconds
Time Before: 0.02820 seconds
Time After: 0.03375 seconds
Time Taken: 0.00556 seconds
Time Before: 0.04844 seconds
Time After: 0.04859 seconds
Time Before: 0.05879 seconds
Time After: 0.06005 seconds
End call of global.php: 0.062400102615356
Time Before: 0.06706 seconds
Time After: 0.06724 seconds
Time Before: 0.07007 seconds
Time After: 0.07154 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=117970'
Time Before: 0.09084 seconds
Time After: 0.09134 seconds
Page generated in 0.089394092559814 seconds with 9 queries, spending 0.0083980560302734 doing MySQL queries and 0.080996036529541 doing PHP things.
