Time Before: 0.00225 seconds
Time After: 0.00284 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00290 seconds
Time After: 0.00332 seconds
Time Before: 0.00350 seconds
Time After: 0.00362 seconds
Time Before: 0.00435 seconds
Time After: 0.00654 seconds
Time Taken: 0.00219 seconds
Time Before: 0.00366 seconds
Time After: 0.00996 seconds
Time Taken: 0.00630 seconds
Time Before: 0.01173 seconds
Time After: 0.01209 seconds
Time Before: 0.01491 seconds
Time After: 0.01619 seconds
Time Before: 0.01113 seconds
Time After: 0.01637 seconds
Time Taken: 0.00524 seconds
Time Before: 0.02144 seconds
Time After: 0.02158 seconds
Time Before: 0.02374 seconds
Time After: 0.02502 seconds
End call of global.php: 0.027559041976929
Time Before: 0.02888 seconds
Time After: 0.02904 seconds
Time Before: 0.03201 seconds
Time After: 0.03355 seconds
Time Taken: 0.00154 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=118003', badlocation = 1
Time Before: 0.05230 seconds
Time After: 0.05257 seconds
Page generated in 0.051146984100342 seconds with 9 queries, spending 0.0077660083770752 doing MySQL queries and 0.043380975723267 doing PHP things.
