Time Before: 0.02548 seconds
Time After: 0.03640 seconds
Time Taken: 0.01091 seconds
Memory Before: 532.883 KB
Memory After: 558.000 KB
Time Before: 0.03650 seconds
Time After: 0.03909 seconds
Time Taken: 0.00258 seconds
Memory Before: 557.938 KB
Memory After: 558.945 KB
Time Before: 0.03943 seconds
Time After: 0.03960 seconds
Memory Before: 559.500 KB
Memory After: 560.023 KB
Time Before: 0.04058 seconds
Time After: 0.04299 seconds
Time Taken: 0.00242 seconds
Memory Before: 562.625 KB
Memory After: 563.547 KB
Time Before: 0.03967 seconds
Time After: 0.04746 seconds
Time Taken: 0.00779 seconds
Memory Before: 559.273 KB
Memory After: 1,640.320 KB
Memory Used: 1,081.047 KB
Time Before: 0.05388 seconds
Time After: 0.05430 seconds
Memory Before: 2,135.250 KB
Memory After: 2,135.867 KB
Time Before: 0.05737 seconds
Time After: 0.05870 seconds
Time Taken: 0.00132 seconds
Memory Before: 2,147.414 KB
Memory After: 2,147.273 KB
Time Before: 0.05295 seconds
Time After: 0.05895 seconds
Time Taken: 0.00601 seconds
Memory Before: 2,127.430 KB
Memory After: 2,260.641 KB
Memory Used: 133.211 KB
Time Before: 0.09600 seconds
Time After: 0.09615 seconds
Memory Before: 2,814.180 KB
Memory After: 2,814.695 KB
Time Before: 0.11520 seconds
Time After: 0.11646 seconds
Memory Before: 2,902.500 KB
Memory After: 2,903.094 KB
Time Before: 0.12962 seconds
Time After: 0.12978 seconds
Memory Before: 3,539.297 KB
Memory After: 3,539.727 KB
Time Before: 0.13236 seconds
Time After: 0.13385 seconds
Memory Before: 3,820.828 KB
Memory After: 3,822.516 KB
UPDATE session SET lastactivity = 1785425789, location = '/forums/private.php?do=newpm&explain=1&u=118022' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.15301 seconds
Time After: 0.15437 seconds
Time Taken: 0.00137 seconds
Memory Before: 4,299.156 KB
Memory After: 4,299.383 KB
