Time Before: 0.03341 seconds
Time After: 0.04000 seconds
Time Taken: 0.00659 seconds
Time Before: 0.04009 seconds
Time After: 0.04052 seconds
Time Before: 0.04081 seconds
Time After: 0.04093 seconds
Time Before: 0.04168 seconds
Time After: 0.04428 seconds
Time Taken: 0.00260 seconds
Time Before: 0.04099 seconds
Time After: 0.04982 seconds
Time Taken: 0.00884 seconds
Time Before: 0.06133 seconds
Time After: 0.06181 seconds
Time Before: 0.06344 seconds
Time After: 0.06463 seconds
Time Before: 0.06066 seconds
Time After: 0.06486 seconds
Time Taken: 0.00419 seconds
Time Before: 0.10890 seconds
Time After: 0.10905 seconds
Time Before: 0.28207 seconds
Time After: 0.28331 seconds
End call of global.php: 0.28622794151306
Time Before: 0.29913 seconds
Time After: 0.29927 seconds
Time Before: 0.30211 seconds
Time After: 0.30362 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=118028', badlocation = 1
Time Before: 0.32304 seconds
Time After: 0.32335 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.32194590568542 seconds with 9 queries, spending 0.0081562995910645 doing MySQL queries and 0.31378960609436 doing PHP things.
