Time Before: 0.02213 seconds
Time After: 0.02660 seconds
Time Taken: 0.00447 seconds
Time Before: 0.02670 seconds
Time After: 0.02759 seconds
Time Taken: 0.00089 seconds
Time Before: 0.02786 seconds
Time After: 0.02803 seconds
Time Before: 0.02884 seconds
Time After: 0.03157 seconds
Time Taken: 0.00273 seconds
Time Before: 0.02810 seconds
Time After: 0.03642 seconds
Time Taken: 0.00832 seconds
Time Before: 0.04671 seconds
Time After: 0.04741 seconds
Time Taken: 0.00070 seconds
Time Before: 0.05001 seconds
Time After: 0.05166 seconds
Time Taken: 0.00165 seconds
Time Before: 0.04594 seconds
Time After: 0.05189 seconds
Time Taken: 0.00594 seconds
Time Before: 0.09663 seconds
Time After: 0.09680 seconds
Time Before: 0.16061 seconds
Time After: 0.16191 seconds
Time Before: 0.17203 seconds
Time After: 0.17221 seconds
Time Before: 0.17490 seconds
Time After: 0.17636 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=118097' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.19476 seconds
Time After: 0.19502 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
