Time Before: 0.00134 seconds
Time After: 0.00180 seconds
Time Before: 0.00187 seconds
Time After: 0.00249 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00275 seconds
Time After: 0.00289 seconds
Time Before: 0.00359 seconds
Time After: 0.00709 seconds
Time Taken: 0.00350 seconds
Time Before: 0.00294 seconds
Time After: 0.01047 seconds
Time Taken: 0.00753 seconds
Time Before: 0.01231 seconds
Time After: 0.01274 seconds
Time Before: 0.01522 seconds
Time After: 0.01654 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01169 seconds
Time After: 0.01677 seconds
Time Taken: 0.00508 seconds
Time Before: 0.02330 seconds
Time After: 0.02348 seconds
Time Before: 0.02570 seconds
Time After: 0.02698 seconds
Time Before: 0.02987 seconds
Time After: 0.03000 seconds
Time Before: 0.03200 seconds
Time After: 0.03343 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=118104', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04589 seconds
Time After: 0.04631 seconds
