Time Before: 0.01252 seconds
Time After: 0.01669 seconds
Time Taken: 0.00417 seconds
Time Before: 0.01680 seconds
Time After: 0.01732 seconds
Time Before: 0.01762 seconds
Time After: 0.01775 seconds
Time Before: 0.01855 seconds
Time After: 0.02127 seconds
Time Taken: 0.00272 seconds
Time Before: 0.01781 seconds
Time After: 0.02532 seconds
Time Taken: 0.00751 seconds
Time Before: 0.03137 seconds
Time After: 0.03174 seconds
Time Before: 0.03417 seconds
Time After: 0.03548 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03068 seconds
Time After: 0.03574 seconds
Time Taken: 0.00505 seconds
Memory After: 2,261.703 KB
Time Before: 0.05411 seconds
Time After: 0.05433 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.06674 seconds
Time After: 0.06799 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.069937944412231
Time Before: 0.07330 seconds
Time After: 0.07348 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.07601 seconds
Time After: 0.07744 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=118110', badlocation = 1
Time Before: 0.09514 seconds
Time After: 0.09554 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.094089984893799 seconds with 9 queries, spending 0.0085349082946777 doing MySQL queries and 0.085555076599121 doing PHP things.
