Time Before: 0.00146 seconds
Time After: 0.00195 seconds
Time Before: 0.00201 seconds
Time After: 0.00256 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00284 seconds
Time After: 0.00300 seconds
Time Before: 0.00390 seconds
Time After: 0.00686 seconds
Time Taken: 0.00296 seconds
Time Before: 0.00308 seconds
Time After: 0.01035 seconds
Time Taken: 0.00726 seconds
Time Before: 0.01214 seconds
Time After: 0.01251 seconds
Time Before: 0.01483 seconds
Time After: 0.01624 seconds
Time Before: 0.01159 seconds
Time After: 0.01641 seconds
Time Taken: 0.00482 seconds
Time Before: 0.02144 seconds
Time After: 0.02164 seconds
Time Before: 0.02416 seconds
Time After: 0.02538 seconds
End call of global.php: 0.026992797851562
Time Before: 0.02841 seconds
Time After: 0.02853 seconds
Time Before: 0.03053 seconds
Time After: 0.03194 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=118112', badlocation = 1
Time Before: 0.04458 seconds
Time After: 0.04490 seconds
Page generated in 0.043629884719849 seconds with 9 queries, spending 0.00872802734375 doing MySQL queries and 0.034901857376099 doing PHP things.
