Time Before: 0.00212 seconds
Time After: 0.00300 seconds
Time Taken: 0.00087 seconds
Time Before: 0.00310 seconds
Time After: 0.00384 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00406 seconds
Time After: 0.00420 seconds
Time Before: 0.00500 seconds
Time After: 0.00746 seconds
Time Taken: 0.00246 seconds
Time Before: 0.00425 seconds
Time After: 0.01089 seconds
Time Taken: 0.00664 seconds
Time Before: 0.01306 seconds
Time After: 0.01331 seconds
Time Before: 0.01665 seconds
Time After: 0.01788 seconds
Time Before: 0.01212 seconds
Time After: 0.01815 seconds
Time Taken: 0.00602 seconds
Time Before: 0.02398 seconds
Time After: 0.02414 seconds
Time Before: 0.02597 seconds
Time After: 0.02719 seconds
Time Before: 0.03056 seconds
Time After: 0.03071 seconds
Time Before: 0.03305 seconds
Time After: 0.03449 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=118118', badlocation = 1 WHERE sessionhash = 'c9ecef9835dff112a7666634a7a1b42a'
Time Before: 0.04742 seconds
Time After: 0.04784 seconds
