Time Before: 0.01302 seconds
Time After: 0.01619 seconds
Time Taken: 0.00317 seconds
Time Before: 0.01630 seconds
Time After: 0.01673 seconds
Time Before: 0.01696 seconds
Time After: 0.01710 seconds
Time Before: 0.01788 seconds
Time After: 0.02018 seconds
Time Taken: 0.00230 seconds
Time Before: 0.01715 seconds
Time After: 0.02428 seconds
Time Taken: 0.00713 seconds
Time Before: 0.02894 seconds
Time After: 0.02937 seconds
Time Before: 0.03187 seconds
Time After: 0.03309 seconds
Time Before: 0.02827 seconds
Time After: 0.03326 seconds
Time Taken: 0.00500 seconds
Time Before: 0.05374 seconds
Time After: 0.05389 seconds
Time Before: 0.06214 seconds
Time After: 0.06347 seconds
Time Taken: 0.00133 seconds
Time Before: 0.06989 seconds
Time After: 0.07006 seconds
Time Before: 0.07242 seconds
Time After: 0.07398 seconds
Time Taken: 0.00156 seconds
UPDATE session SET lastactivity = 1788890822, location = '/forums/private.php?do=newpm&explain=1&u=118146' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.09072 seconds
Time After: 0.09101 seconds
