Time Before: 0.00197 seconds
Time After: 0.00261 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00289 seconds
Time After: 0.00349 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00380 seconds
Time After: 0.00394 seconds
Time Before: 0.00465 seconds
Time After: 0.00706 seconds
Time Taken: 0.00241 seconds
Time Before: 0.00400 seconds
Time After: 0.01048 seconds
Time Taken: 0.00648 seconds
Time Before: 0.01243 seconds
Time After: 0.01282 seconds
Time Before: 0.01602 seconds
Time After: 0.01724 seconds
Time Before: 0.01180 seconds
Time After: 0.01744 seconds
Time Taken: 0.00564 seconds
Time Before: 0.02283 seconds
Time After: 0.02299 seconds
Time Before: 0.02488 seconds
Time After: 0.02609 seconds
Time Before: 0.02944 seconds
Time After: 0.02958 seconds
Time Before: 0.03162 seconds
Time After: 0.03305 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=118167' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04542 seconds
Time After: 0.04578 seconds
