Time Before: 0.00161 seconds
Time After: 0.00209 seconds
Time Before: 0.00216 seconds
Time After: 0.00270 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00290 seconds
Time After: 0.00302 seconds
Time Before: 0.00369 seconds
Time After: 0.00621 seconds
Time Taken: 0.00253 seconds
Time Before: 0.00307 seconds
Time After: 0.00961 seconds
Time Taken: 0.00654 seconds
Time Before: 0.01143 seconds
Time After: 0.01184 seconds
Time Before: 0.01553 seconds
Time After: 0.01670 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01083 seconds
Time After: 0.01687 seconds
Time Taken: 0.00604 seconds
Time Before: 0.02213 seconds
Time After: 0.02226 seconds
Time Before: 0.02426 seconds
Time After: 0.02557 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.027214050292969
Time Before: 0.02848 seconds
Time After: 0.02860 seconds
Time Before: 0.03071 seconds
Time After: 0.03215 seconds
SET lastactivity = 1783068464, location = '/forums/private.php?do=newpm&explain=1&u=118196', badlocation = 1
Time Before: 0.04765 seconds
Time After: 0.04797 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
Page generated in 0.046748876571655 seconds with 9 queries, spending 0.0080928802490234 doing MySQL queries and 0.038655996322632 doing PHP things.
