Time Before: 0.00600 seconds
Time After: 0.00744 seconds
Time Before: 0.00751 seconds
Time After: 0.00820 seconds
Time Taken: 0.00070 seconds
Time Before: 0.00848 seconds
Time After: 0.00863 seconds
Time Before: 0.00936 seconds
Time After: 0.01211 seconds
Time Taken: 0.00275 seconds
Time Before: 0.00868 seconds
Time After: 0.01553 seconds
Time Taken: 0.00684 seconds
Time Before: 0.01914 seconds
Time After: 0.01953 seconds
Time Before: 0.02204 seconds
Time After: 0.02323 seconds
Time Before: 0.01852 seconds
Time After: 0.02340 seconds
Time Taken: 0.00489 seconds
Time Before: 0.03507 seconds
Time After: 0.03522 seconds
Time Before: 0.03957 seconds
Time After: 0.04096 seconds
Time Taken: 0.00139 seconds
End call of global.php: 0.042654037475586
Time Before: 0.04556 seconds
Time After: 0.04572 seconds
Time Before: 0.04771 seconds
Time After: 0.04915 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=118200', badlocation = 1
Time Before: 0.06209 seconds
Time After: 0.06235 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
Page generated in 0.061193943023682 seconds with 9 queries, spending 0.0085794925689697 doing MySQL queries and 0.052614450454712 doing PHP things.
