Time Before: 0.00774 seconds
Time After: 0.00999 seconds
Time Taken: 0.00225 seconds
Time Before: 0.01007 seconds
Time After: 0.01082 seconds
Time Taken: 0.00076 seconds
Time Before: 0.01108 seconds
Time After: 0.01124 seconds
Time Before: 0.01207 seconds
Time After: 0.01462 seconds
Time Taken: 0.00255 seconds
Time Before: 0.01130 seconds
Time After: 0.01976 seconds
Time Taken: 0.00845 seconds
Time Before: 0.02398 seconds
Time After: 0.02437 seconds
Time Before: 0.02698 seconds
Time After: 0.02846 seconds
Time Before: 0.02332 seconds
Time After: 0.02867 seconds
Time Taken: 0.00534 seconds
Time Before: 0.04228 seconds
Time After: 0.04243 seconds
Time Before: 0.04824 seconds
Time After: 0.04961 seconds
Time Taken: 0.00137 seconds
End call of global.php: 0.052036046981812
Time Before: 0.05555 seconds
Time After: 0.05570 seconds
Time Before: 0.05830 seconds
Time After: 0.05972 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=118203', badlocation = 1
Time Before: 0.07436 seconds
Time After: 0.07463 seconds
Page generated in 0.073240995407104 seconds with 9 queries, spending 0.008709192276001 doing MySQL queries and 0.064531803131104 doing PHP things.
