Time Before: 0.01092 seconds
Time After: 0.01548 seconds
Time Taken: 0.00456 seconds
Time Before: 0.01559 seconds
Time After: 0.01604 seconds
Time Before: 0.01627 seconds
Time After: 0.01640 seconds
Time Before: 0.01721 seconds
Time After: 0.01965 seconds
Time Taken: 0.00244 seconds
Time Before: 0.01646 seconds
Time After: 0.02415 seconds
Time Taken: 0.00769 seconds
Time Before: 0.02773 seconds
Time After: 0.02812 seconds
Time Before: 0.03067 seconds
Time After: 0.03188 seconds
Time Before: 0.02712 seconds
Time After: 0.03208 seconds
Time Taken: 0.00496 seconds
Time Before: 0.04785 seconds
Time After: 0.04804 seconds
Time Before: 0.05421 seconds
Time After: 0.05543 seconds
End call of global.php: 0.057348012924194
Time Before: 0.06062 seconds
Time After: 0.06076 seconds
Time Before: 0.06320 seconds
Time After: 0.06465 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=118236'
Time Before: 0.08149 seconds
Time After: 0.08181 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
Page generated in 0.08026385307312 seconds with 9 queries, spending 0.0079419612884521 doing MySQL queries and 0.072321891784668 doing PHP things.
