Time Before: 0.02165 seconds
Time After: 0.02889 seconds
Time Taken: 0.00724 seconds
Time Before: 0.02902 seconds
Time After: 0.02958 seconds
Time Taken: 0.00056 seconds
Time Before: 0.02982 seconds
Time After: 0.02999 seconds
Time Before: 0.03087 seconds
Time After: 0.03293 seconds
Time Taken: 0.00206 seconds
Time Before: 0.03007 seconds
Time After: 0.03824 seconds
Time Taken: 0.00818 seconds
Time Before: 0.04644 seconds
Time After: 0.04685 seconds
Time Before: 0.04979 seconds
Time After: 0.05185 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04580 seconds
Time After: 0.05205 seconds
Time Taken: 0.00625 seconds
Memory After: 2,261.820 KB
Time Before: 0.09505 seconds
Time After: 0.09517 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.12166 seconds
Time After: 0.12293 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.13500 seconds
Time After: 0.13517 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.13829 seconds
Time After: 0.13974 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789040349, location = '/forums/private.php?do=newpm&explain=1&u=118263' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.15815 seconds
Time After: 0.15848 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
