Time Before: 0.00437 seconds
Time After: 0.00534 seconds
Time Taken: 0.00097 seconds
Time Before: 0.00545 seconds
Time After: 0.00591 seconds
Time Before: 0.00615 seconds
Time After: 0.00631 seconds
Time Before: 0.00708 seconds
Time After: 0.01046 seconds
Time Taken: 0.00337 seconds
Time Before: 0.00639 seconds
Time After: 0.01415 seconds
Time Taken: 0.00776 seconds
Time Before: 0.01692 seconds
Time After: 0.01733 seconds
Time Before: 0.01999 seconds
Time After: 0.02118 seconds
Time Before: 0.01613 seconds
Time After: 0.02143 seconds
Time Taken: 0.00530 seconds
Time Before: 0.02873 seconds
Time After: 0.02891 seconds
Time Before: 0.03089 seconds
Time After: 0.03220 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.035176038742065
Time Before: 0.03673 seconds
Time After: 0.03692 seconds
Time Before: 0.04024 seconds
Time After: 0.04173 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=118284', badlocation = 1
Time Before: 0.05648 seconds
Time After: 0.05678 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.055490016937256 seconds with 9 queries, spending 0.0090799331665039 doing MySQL queries and 0.046410083770752 doing PHP things.
