Time Before: 0.01642 seconds
Time After: 0.02022 seconds
Time Taken: 0.00380 seconds
Time Before: 0.02030 seconds
Time After: 0.02072 seconds
Time Before: 0.02094 seconds
Time After: 0.02113 seconds
Time Before: 0.02202 seconds
Time After: 0.02502 seconds
Time Taken: 0.00300 seconds
Time Before: 0.02120 seconds
Time After: 0.03096 seconds
Time Taken: 0.00976 seconds
Time Before: 0.03821 seconds
Time After: 0.03843 seconds
Time Before: 0.03979 seconds
Time After: 0.04101 seconds
Time Before: 0.03750 seconds
Time After: 0.04121 seconds
Time Taken: 0.00370 seconds
Time Before: 0.06365 seconds
Time After: 0.06385 seconds
Time Before: 0.08003 seconds
Time After: 0.08130 seconds
End call of global.php: 0.083858966827393
Time Before: 0.09079 seconds
Time After: 0.09096 seconds
Time Before: 0.09347 seconds
Time After: 0.09499 seconds
Time Taken: 0.00152 seconds
SET lastactivity = 1780637395, location = '/forums/private.php?do=newpm&explain=1&u=118292', badlocation = 1
Time Before: 0.11460 seconds
Time After: 0.11489 seconds
Page generated in 0.11350011825562 seconds with 9 queries, spending 0.0084900856018066 doing MySQL queries and 0.10501003265381 doing PHP things.
