Time Before: 0.00204 seconds
Time After: 0.00258 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00266 seconds
Time After: 0.00337 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00372 seconds
Time After: 0.00392 seconds
Time Before: 0.00461 seconds
Time After: 0.00773 seconds
Time Taken: 0.00312 seconds
Time Before: 0.00399 seconds
Time After: 0.01112 seconds
Time Taken: 0.00713 seconds
Time Before: 0.01297 seconds
Time After: 0.01337 seconds
Time Before: 0.01595 seconds
Time After: 0.01787 seconds
Time Taken: 0.00192 seconds
Time Before: 0.01245 seconds
Time After: 0.01804 seconds
Time Taken: 0.00559 seconds
Time Before: 0.02297 seconds
Time After: 0.02312 seconds
Time Before: 0.02514 seconds
Time After: 0.02638 seconds
End call of global.php: 0.027975082397461
Time Before: 0.02951 seconds
Time After: 0.02974 seconds
Time Before: 0.03169 seconds
Time After: 0.03321 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1785385236, location = '/forums/private.php?do=newpm&explain=1&u=118295'
WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.04535 seconds
Time After: 0.04571 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.044471979141235 seconds with 9 queries, spending 0.0098342895507812 doing MySQL queries and 0.034637689590454 doing PHP things.
