Time Before: 0.01427 seconds
Time After: 0.01709 seconds
Time Taken: 0.00282 seconds
Time Before: 0.01717 seconds
Time After: 0.01767 seconds
Time Before: 0.01793 seconds
Time After: 0.01819 seconds
Time Before: 0.01917 seconds
Time After: 0.02181 seconds
Time Taken: 0.00265 seconds
Time Before: 0.01827 seconds
Time After: 0.02582 seconds
Time Taken: 0.00754 seconds
Time Before: 0.03136 seconds
Time After: 0.03186 seconds
Time Before: 0.03433 seconds
Time After: 0.03561 seconds
Time Before: 0.03071 seconds
Time After: 0.03595 seconds
Time Taken: 0.00524 seconds
Time Before: 0.05419 seconds
Time After: 0.05433 seconds
Time Before: 0.12126 seconds
Time After: 0.12263 seconds
Time Taken: 0.00136 seconds
Time Before: 0.12943 seconds
Time After: 0.12962 seconds
Time Before: 0.13301 seconds
Time After: 0.13442 seconds
UPDATE session SET lastactivity = 1785299124, location = '/forums/private.php?do=newpm&explain=1&u=11833', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.15109 seconds
Time After: 0.15134 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
