Time Before: 0.00132 seconds
Time After: 0.00185 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00192 seconds
Time After: 0.00239 seconds
Time Before: 0.00266 seconds
Time After: 0.00280 seconds
Time Before: 0.00340 seconds
Time After: 0.00636 seconds
Time Taken: 0.00296 seconds
Time Before: 0.00284 seconds
Time After: 0.01123 seconds
Time Taken: 0.00839 seconds
Time Before: 0.01357 seconds
Time After: 0.01393 seconds
Time Before: 0.01585 seconds
Time After: 0.01705 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01287 seconds
Time After: 0.01724 seconds
Time Taken: 0.00437 seconds
Memory After: 2,261.703 KB
Time Before: 0.02233 seconds
Time After: 0.02247 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02418 seconds
Time After: 0.02539 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.02850 seconds
Time After: 0.02870 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03057 seconds
Time After: 0.03203 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=118346', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04671 seconds
Time After: 0.04704 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
