Time Before: 0.02672 seconds
Time After: 0.03230 seconds
Time Taken: 0.00558 seconds
Time Before: 0.03242 seconds
Time After: 0.03447 seconds
Time Taken: 0.00205 seconds
Time Before: 0.03466 seconds
Time After: 0.03481 seconds
Time Before: 0.03561 seconds
Time After: 0.04045 seconds
Time Taken: 0.00485 seconds
Time Before: 0.03487 seconds
Time After: 0.04527 seconds
Time Taken: 0.01040 seconds
Time Before: 0.05455 seconds
Time After: 0.05477 seconds
Time Before: 0.05731 seconds
Time After: 0.05881 seconds
Time Taken: 0.00150 seconds
Time Before: 0.05376 seconds
Time After: 0.05905 seconds
Time Taken: 0.00529 seconds
Time Before: 0.10290 seconds
Time After: 0.10305 seconds
Time Before: 0.45864 seconds
Time After: 0.46020 seconds
Time Taken: 0.00156 seconds
Time Before: 0.47177 seconds
Time After: 0.47195 seconds
Time Before: 0.47453 seconds
Time After: 0.47606 seconds
Time Taken: 0.00153 seconds
UPDATE session SET lastactivity = 1783099064, location = '/forums/private.php?do=newpm&explain=1&u=118347' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.49674 seconds
Time After: 0.49699 seconds
