Time Before: 0.01422 seconds
Time After: 0.02065 seconds
Time Taken: 0.00643 seconds
Time Before: 0.02076 seconds
Time After: 0.02116 seconds
Time Before: 0.02141 seconds
Time After: 0.02156 seconds
Time Before: 0.02295 seconds
Time After: 0.02537 seconds
Time Taken: 0.00241 seconds
Time Before: 0.02163 seconds
Time After: 0.02970 seconds
Time Taken: 0.00807 seconds
Time Before: 0.03802 seconds
Time After: 0.03847 seconds
Time Before: 0.04203 seconds
Time After: 0.04322 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03719 seconds
Time After: 0.04343 seconds
Time Taken: 0.00624 seconds
Memory After: 2,261.703 KB
Time Before: 0.06814 seconds
Time After: 0.06852 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.08647 seconds
Time After: 0.08768 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.089540958404541
Time Before: 0.09542 seconds
Time After: 0.09557 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.09800 seconds
Time After: 0.09966 seconds
Time Taken: 0.00166 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=118353', badlocation = 1
Time Before: 0.11702 seconds
Time After: 0.11740 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.11598992347717 seconds with 9 queries, spending 0.0083765983581543 doing MySQL queries and 0.10761332511902 doing PHP things.
