Time Before: 0.00224 seconds
Time After: 0.00278 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00285 seconds
Time After: 0.00340 seconds
Time Before: 0.00362 seconds
Time After: 0.00373 seconds
Time Before: 0.00447 seconds
Time After: 0.00678 seconds
Time Taken: 0.00231 seconds
Time Before: 0.00378 seconds
Time After: 0.01155 seconds
Time Taken: 0.00776 seconds
Time Before: 0.01379 seconds
Time After: 0.01425 seconds
Time Before: 0.01583 seconds
Time After: 0.01703 seconds
Time Before: 0.01304 seconds
Time After: 0.01722 seconds
Time Taken: 0.00418 seconds
Time Before: 0.02246 seconds
Time After: 0.02261 seconds
Time Before: 0.02481 seconds
Time After: 0.02621 seconds
Time Taken: 0.00140 seconds
Time Before: 0.03016 seconds
Time After: 0.03032 seconds
Time Before: 0.03327 seconds
Time After: 0.03519 seconds
Time Taken: 0.00192 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=118403' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04754 seconds
Time After: 0.04815 seconds
Time Taken: 0.00061 seconds
