Time Before: 0.00175 seconds
Time After: 0.00226 seconds
Time Before: 0.00234 seconds
Time After: 0.00284 seconds
Time Before: 0.00308 seconds
Time After: 0.00328 seconds
Time Before: 0.00408 seconds
Time After: 0.00693 seconds
Time Taken: 0.00286 seconds
Time Before: 0.00334 seconds
Time After: 0.01185 seconds
Time Taken: 0.00852 seconds
Time Before: 0.01364 seconds
Time After: 0.01398 seconds
Time Before: 0.01656 seconds
Time After: 0.01941 seconds
Time Before: 0.01309 seconds
Time After: 0.01962 seconds
Time Taken: 0.00653 seconds
Time Before: 0.02592 seconds
Time After: 0.02607 seconds
Time Before: 0.02808 seconds
Time After: 0.02937 seconds
End call of global.php: 0.031831026077271
Time Before: 0.03320 seconds
Time After: 0.03382 seconds
Time Taken: 0.00061 seconds
Time Before: 0.03642 seconds
Time After: 0.03838 seconds
Time Taken: 0.00196 seconds
SET lastactivity = 1785350240, location = '/forums/private.php?do=newpm&explain=1&u=118406', badlocation = 1
Time Before: 0.05103 seconds
Time After: 0.05133 seconds
Page generated in 0.050118923187256 seconds with 9 queries, spending 0.011085987091064 doing MySQL queries and 0.039032936096191 doing PHP things.
