Time Before: 0.01003 seconds
Time After: 0.01193 seconds
Time Taken: 0.00190 seconds
Time Before: 0.01203 seconds
Time After: 0.01269 seconds
Time Taken: 0.00066 seconds
Time Before: 0.01294 seconds
Time After: 0.01310 seconds
Time Before: 0.01395 seconds
Time After: 0.01628 seconds
Time Taken: 0.00233 seconds
Time Before: 0.01318 seconds
Time After: 0.02070 seconds
Time Taken: 0.00752 seconds
Time Before: 0.02458 seconds
Time After: 0.02498 seconds
Time Before: 0.02757 seconds
Time After: 0.02879 seconds
Time Before: 0.02394 seconds
Time After: 0.02901 seconds
Time Taken: 0.00507 seconds
Time Before: 0.04285 seconds
Time After: 0.04300 seconds
Time Before: 0.04880 seconds
Time After: 0.05010 seconds
Time Before: 0.05614 seconds
Time After: 0.05629 seconds
Time Before: 0.05884 seconds
Time After: 0.06033 seconds
UPDATE session SET lastactivity = 1785311698, location = '/forums/private.php?do=newpm&explain=1&u=118462', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.07681 seconds
Time After: 0.07713 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
