Time Before: 0.01047 seconds
Time After: 0.01496 seconds
Time Taken: 0.00449 seconds
Time Before: 0.01506 seconds
Time After: 0.01551 seconds
Time Before: 0.01572 seconds
Time After: 0.01587 seconds
Time Before: 0.01667 seconds
Time After: 0.01910 seconds
Time Taken: 0.00243 seconds
Time Before: 0.01593 seconds
Time After: 0.02353 seconds
Time Taken: 0.00760 seconds
Time Before: 0.02888 seconds
Time After: 0.02910 seconds
Time Before: 0.03089 seconds
Time After: 0.03356 seconds
Time Taken: 0.00266 seconds
Time Before: 0.02813 seconds
Time After: 0.03380 seconds
Time Taken: 0.00567 seconds
Time Before: 0.05502 seconds
Time After: 0.05518 seconds
Time Before: 0.06599 seconds
Time After: 0.06726 seconds
End call of global.php: 0.069205045700073
Time Before: 0.07493 seconds
Time After: 0.07555 seconds
Time Taken: 0.00062 seconds
Time Before: 0.07799 seconds
Time After: 0.07982 seconds
Time Taken: 0.00183 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=118472', badlocation = 1
Time Before: 0.09567 seconds
Time After: 0.09591 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.094671964645386 seconds with 9 queries, spending 0.010025262832642 doing MySQL queries and 0.084646701812744 doing PHP things.
