Time Before: 0.00145 seconds
Time After: 0.00204 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00211 seconds
Time After: 0.00264 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00282 seconds
Time After: 0.00296 seconds
Time Before: 0.00367 seconds
Time After: 0.00626 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00301 seconds
Time After: 0.00978 seconds
Time Taken: 0.00677 seconds
Time Before: 0.01157 seconds
Time After: 0.01183 seconds
Time Before: 0.01431 seconds
Time After: 0.01551 seconds
Time Before: 0.01096 seconds
Time After: 0.01568 seconds
Time Taken: 0.00472 seconds
Time Before: 0.02061 seconds
Time After: 0.02075 seconds
Time Before: 0.02272 seconds
Time After: 0.02395 seconds
Time Before: 0.02693 seconds
Time After: 0.02708 seconds
Time Before: 0.02908 seconds
Time After: 0.03050 seconds
UPDATE session SET lastactivity = 1780640959, location = '/forums/private.php?do=newpm&explain=1&u=118593' WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.04322 seconds
Time After: 0.04353 seconds
